maryam_nourmand
publish prediction formula
hello.
i have a question
i need the python code of the neural method ,for this reason i use publish prediction formula part
but when i run the code i get an error :
ModuleNotFoundError                       Traceback (most recent call last)
~\AppData\Local\Temp\ipykernel_11660\144293927.py in <module>
      1 from __future__ import division
----> 2 import jmp_score as jmp
      3 from math import *
      4 import numpy as np
      5
ModuleNotFoundError: No module named 'jmp_score'
what should i do ?!!
Re: publish prediction formula
If I remember correctly that file (jmp_score.py) is found from JMP installation folder.
https://www.jmp.com/support/help/en/17.2/#page/jmp/generate-scoring-code-from-the-formula-depot-plat...
maryam_nourmand
thanks for your answer
now i can run the code without gettiong ERROR
but another problem is
the results of python code are diffrent from the result of jmp software
why ?!!!
