Raaed
panel data models
hi every one
plm is a package for R which intends to make the estimation of linear panel models straightforward.
plm provides functions to estimate a wide variety of models and to make inference by using real data.
my question is how to applied panel data models using simulation data?
thanks
Řaëd ~✍
Phil_Kay
Re: panel data
I think that you will need to provide more information about what you are trying to achieve to help the community to help you.
Regards,
Phil
Raaed
Re: panel data
Řaëd ~✍
Phil_Kay
Re: panel data
Thanks for the additional information. I am sorry but I still do not understand how I can help.
It should be possible to fit some panel models in JMP or JMP Pro. You might want to search for "Mixed Models" or "Random Effects Models". This resource from @jiancao might be useful.
If you want help to fit specific panel models in JMP then the best thing that you can do is to attach some example data along with a description of the model that you would like to fit.
I hope that helps.
Regards,
Phil
