Ross_ST
rows selection
Dear all,
I am writing to solve a problem about rows selection in data table I have obtained by import of Current-Voltage data of a set of samples. .
final Data table is made by three columns: Current, Voltage, File Name.
I want to clean the Table from the last row of each group of data corresponding to the same FileName.
It is possible?
Thank you
Ross
Re: rows selection
I am not quite sure what you mean when you say "I want to clean the Table".  Here is a short piece of JSL that will find the last row for each of the FileNames
dt = Current Data Table();
dt << select where( Row() == Col Max( Row(), :FileName ) );
Is this providing you the information you need?
