NetflixCrow956
move columns
Hello everyone, I would like to shift all columns to the right by one column if the lines where the length is greater than 3 in the first column and I would like to know if this is possible? for the moment, I starting by this :
dt << delete row( 1 );
rows_to_delete = dt << Get Rows Where(Length( :Prodn Supervisor )>3);
If(N Items(rows_to_delete),
	dt << Delete Rows(rows_to_delete);
Re: move columns
Depending on your data something like this might work, it uses Data table subscripting
dt = New Table("Untitled",
	Add Rows(4),
	New Column("A", Character, "Nominal", Set Values({"AAAA", "AAAA", "BBB", "BBB"})),
	New Column("B", Character, "Nominal", Set Values({"123", "456", "AAAA", "AAAA"}), Set Display Width(45)),
	New Column("C", Numeric, "Continuous", Format("Best", 12), Set Values([., ., 789, 0]))
rows_to_shift =  dt << Get Rows Where(Length(AsColumn(1)) > 3);
col_count = N Cols(dt);
// set all columns to character to make this easier
For Each({col_name}, dt << Get Column Names("String"),
	Column(dt, col_name) << Set Data Type("Character");
wait(1);
// Datatable subscripting
dt[rows_to_shift, 2::col_count] = dt[rows_to_shift, 1::col_count - 1];
dt[rows_to_shift, 1] = ""; // set first column values as missing
NetflixCrow956
Re: move columns
For the moment I delete these columns but I would like to move them to the right as explained above
Re: move columns
	Add Rows(4),
wait(1);
Re: move columns
Something like this should work
dt = Current Data Table();
theRows = dt << Get Rows Where( Length( :Prodn Supervisor ) > 3 );
If( N Items( theRows ) > 0,
	For( theCol = 1, theCol < N Col( dt ), theCol++,
		For( myRow = 1, myRow <= N Items( theRows ), myRow++,
			Column( theCol )[theRows[myRow]] = Column( theCol + 1 )[theRows[myRow]]
