aicilastats
How to get "Effect size" column with Response Screening functionality
Hello everyone,
I am using the response screening feature of jmp and I was wondering how the columns are calculated, especially the Effect Size column.
My database contains discrete and continuous variables.
I want to perform a first analysis by selecting only the categorical variables as explanatory variables
And a second analysis by selecting only the continuous variables as explanatory variables.
My response variable is continuous.
However, I wonder how this "Effect Size" column is calculated and if the calculation method is the same or not depending on the nature of the explanatory variables.
Thank you very much
Re: How to get "Effect size" column with Response Screening functionality
aicilastats
Thank you very much!
