john_hutchinson
make a control chart with a variable for column
I want to make different control charts based on different columns of data, where the column name are numbers based on an SPC chart numbering system.
For example if I want a control chart based on column "45038", this works fine
chartnum = 45038;
ct1 = Control Chart(
    Sample Label( :lot ),
    KSigma( 3 ),
    GetLimits(\limits.jmp" ),
    Chart Col(
        :"45038",
        XBar( Limits Precision( 0 ) ),
        R( Limits Precision( 0 ))
I can replace :"45038" with name("45038").  But I get a syntax error if I replace it with name (chartnum) or name(char(chartnum))
Any ideas?
ms
Super User ms
Re: make a control chart with a variable for column
Try
As Column(Char(chartnum))
Or simply
:(Char(chartnum))
john_hutchinson
Thank you for the suggestion!
Both options enable to control chart to display the data from the appropriate column.
Unfortunately, both options do not find the control limits in my limits.jmp table.  Odd.
    KSigma( 3 ),
    GetLimits("C:\_LOCAL\_Aurrion\_ToBeSorted\charts-working\JMP\limits.jmp" ),
    Chart Col(
//        :(Char(chartnum)), // display chart, but doesn't find limits in file.
        :"45038", // display chart and correct limits
//        As Column(Char(chartnum)), // displays chart, but doesn't get limits from file.
ms
Super User ms
Ok, maybe a reference for the column is needed. Try this:
dt = Current Data Table();
chartnum = 45038;
col = Column(dt, Char(chartnum));
    Sample Label(:lot),
    KSigma(3),
    Chart Col(col, XBar(Limits Precision(0)), R(Limits Precision(0))),
    GetLimits("C:\_LOCAL\_Aurrion\_ToBeSorted\charts-working\JMP\limits.jmp")
john_hutchinson
Thanks!
I dont quite understand the different behaviors, but it works!
