ezorlo
lines in stacked bar plot
i made a beautiful stacked bar plot
the only problem is that I lose the lines between categories when i export the graph
so I want to make the lines more bold. Any ideas?
example of what i am trying to accomplish, below
* make the white lines in the bar plots more bold/different color
thanks
Re: lines in stacked bar plot
I am not aware of an option to increase the white line thickness.  The only way that I see that might be able to work, would be to use the
     << add graphics script
capability within JMP, and to add white lines to the graph.
