BookmarkSubscribeRSS Feed
hardner
Nov 13, 2012
is having data table as an argument to summarize() new in JMP12?
I had to give up all earlier versions to install JMP12 so can't test this directly but suspecting syntax like this fails in earlier versions?
summarize(dt,var=by(columnname));
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: is having data table as an argument to summarize() new in JMP12?
Yes, that's new in JMP 12.
Here's what you get in JMP 11.
dt=open("$SAMPLE_DATA\Big Class.jmp");
columnname=column("Age");
Must be Assign Operator in access or evaluation of 'dt' , dt/*###*/
In the following script, error marked by /*###*/
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
columnname = Column( "Age" );
Summarize( dt/*###*/, var = by( columnname ) );
-Jeff
-Jeff
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
-Jeff
hardner
Nov 13, 2012
Thanks!  Discovering it the hard way by accidentally using that in a script to be run by folks who haven't updated to JMP12 but it's a good feature.
