  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
Stokes
interpolate missing data value based on its neighbouring data
I have a work need to find the missing value based on its neighbouring value.
The value can be found below with its x,y coordinates.
The goal is to calculate the Z_value based on its neighbouring value fitting, such as contour map method.
THanks
xyZ_Value
1201803.48
181146
1841203.3
1841803.28
1842403.13
187205
19092
190268
19177
192152
215154
216243
226218
23579
248603.8
2481203.42
2481803.31
2482403.36
2483003.18
250268
251142
25387
253205
271255
277193
29586
298157
3121203.64
3121803.46
3122403.38
313208
313263
319149
335164
353177
3761803.31
Re: interpolate missing data value based on its neighbouring data
The contour plot platform allows you to create a new data table where the xy matrix can be interpolated to whatever precision desired.
From the red triangle, select
     Save=>Generated Grid
Here is the example taken directly from the Scripting Index
dt = Open( "$SAMPLE_DATA/Little Pond.jmp" );
obj = dt << Contour Plot( X( :X, :Y ), Y( :Z ) );
obj << Generate Grid( 11, 11 );
Stokes
This works, thanks.
By any chance, do you happen to know the JSL for the grid generation?
I am trying to use table copy script, but it doesn't work.
For example,to generate a 21 horizontal grid, and a 32 vertical grid.
Stokes
This is great, thanks
