I bit more information is needed. You could for example collect them into V List Box and then display using New Window
dt = open("$SAMPLE_DATA/Big Class.jmp");
gb_collector = V List Box();
For(i = 1, i <= 3, i++,
gb_collector << Append(
dt << Graph Builder(
Variables(X(:weight), Y(:height), Overlay(:sex)),
Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
nw = New Window("",
gb_collector
If you are utilizing For loop I assume you are doing scripting. Have you read Scripting Guide (for example https://www.jmp.com/support/help/en/18.0/#page/jmp/examples-of-creating-a-dashboard-from-two-reports... ).
