Created:
Feb 2, 2023 03:11 AM
| Last Modified: Jun 27, 2023 12:43 PM(3157 views)
I wanted to export a plot to an interactive HTML file.
The file was quite large, therefore I tried to reduce the size by generating the plot from a data view of the non-excluded rows.
Surprisingly, the file size was even bigger
The solution was:
Remove the link between data view and the original table (alternative: generate the subset without link :).
The behavior seems to depend on the plot type; for other plot types, the plot from the data view has a reduced file size compared to a plot from the original data table - but it's still quite big compared to a file that is generated with out a link.
Would it make sense that the html export is automatically generated for a temporary data set with cut link - or alternatively: a warning could show up in the log telling the user that he could reduce the file size by cutting the link.
Thank you for posting this question and the wish accompanying it.
Maintaining the link between a subset and its source table(s) requires storing relevant source table information and the links to that table. So, the additional information is expected.
In many cases, the link is not required for the report or dashboard you're exporting, but our export process does not have enough information to detect those situations. It would be best if that could be explicitly stated before exporting by cutting the link as you suggest. That way, any change in behavior caused by cutting the link in some cases can be experienced before exporting.
We can consider adding a warning in the log about the additional data requirements of linked data sets, but it will need to be written in a way that doesn't alarm users that do intend to maintain the linked behavior.
A JSL query to query a table about whether it is a linked subset did not previously exist. However, this conversation has caught the attention of JMP Development, and now a JSL message has been added in the next major release of JMP (JMP 18).
dt << Is Linked Subset; //will return 1 or 0
(I posted in the other thread linked to by @hogi as well.)
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '596256' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '596256') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '596256') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
