import of a Excel file with column name containing formulas
Mar 7, 2024 05:26 AM(4760 views)
Hello all,
I would like to import an Excel file in JMP. However, the column name are formulas that allow to import names from another Excel sheet and it doesn't work. Here are the names of the imported column:
Do you know if the is a way to import a such Excel file?
Have you tried opening the Excel sheet, and using the JMP Addin for Excel to move the data? If the table isn't too large, you could try to cut and paste it.
