jueefo
Informat (ParseDate) function with time
I have a question about Informat function (or its alias ParseDate). If I have a string with date and time information, and I try to parse date on JMP 15.2.0.
str="2022-10-22 16:25:37";
datetime= Informat( str, "yyyy-mm-dd HH:mm:ss" );
show(type(datetime));
show(datetime);
I get output different kind of outputs, depending on date time settings (Win 10).
Regional format English (United Kingdom):
str = "2022-10-22 16:23:37";
Type(datetime) = "Date";
datetime = 22Oct2022:16:23:37;
Or Regional format Finnish (Finland):
Type(datetime) = "Number";
datetime = .;
Is there a function that could parse time also? Or are there suggestions how this could be done?
Re: Informat (ParseDate) function with time
Here is one way to handle the issue
datetime = datemdy(num(word(2,str," -:")),
	num(word(3,str," -:")),
	num(word(1,str," -:")) ) +
	3600*num(word(4,str," -:")) +
	60 * num(word(5,str," -:")) +
	num(word(6,str," -:")
show(format(datetime,"m/d/y h:m:s"));
It shows in the log
Format(datetime, "m/d/y h:m:s") = "10/22/2022 4:25:37 PM";
Check out if using << Use Locale() helps at all.
JMP was fairly bad at managing managing time (and dates) before JMP16. I would most likely parse the string to year, month, day, hour, minute and second. Then sum those to get date_time. With JMP16 you could most likely just use Format Pattern
Maybe this can give some ideas:
str = "2022-10-22 16:25:37";
date = Word(1, str, " ");
time = Word(2, str, " ");
y = Num(Word(1, date, "-"));
m = Num(Word(2, date, "-"));
d = Num(Word(3, date, "-"));
time_separator = Left(Regex(Format(Today(), "h:m:s"), "\d", "", GLOBALREPLACE), 1);
hh = Num(Word(1, time, time_separator));
mm = Num(Word(2, time, time_separator));
ss = Num(Word(3, time, time_separator));
date_time = Date DMY(d, m, y) + hh * 60 * 60 + mm * 60 + ss;
AsDate(date_time);
jueefo
I have used << Use Locale() to overcome issues with date and time formats. The example you provided did not solve issue, I  think that I come back to this later when I have time (pun intended). The issue with the example is most probably solved with << Use Locale(). I'll also try Format Pattern, if I get newer version of the JMP.
Thanks again sharing your knowledge.
It shows in the log
jueefo
Thank you, this example works for the datetime settings tested.
hogi
Level XIII
It seems that in Jmp 15.2 Informat just ignored fancy patterns like
Even pattern = "hello" results in
In later versions, Jmp will tell the user:
Unknown format: hello
What works:
Informat with the option Format Pattern:
datetime= Informat( str, "Format Pattern", "<YYYY></><MM></><DD> <hh><:><mm><:><ss>" );
show(datetime);
