jmpbeginner
how to rename summary table column (not column# dependent)
I am creating a summary table and need to rename the columns. example:
Summary(
  Group( :RECIPE_FW ),
  Mean ( :MTBW),
  N( :MTBW ),
  output table name("testOutput")
I found that I can reference the column # to rename:
MTBW = Column(3);
MTBW << Set Name ("MTBW (w/Outliers)");
nMTBW = Column(4);
nMTBW << Set Name ("nMTBW");
My concern with this approach is that if more columns are added/inserted, these column(#) references will then rename the wrong column.  Is there a way to rename these columns within the Summary( ) portion? I tried the following and could not get it to work:
Summary(
  Mean ( :MTBW)<< Set Name ("MTBW (w/Outliers)"),
  N( :MTBW )<< Set Name ("nMTBW"),
any help is greatly appreciated! thanks!
pmroz
Re: how to rename summary table column (not column# dependent)
dt = data table("testOutput");
column(dt, "Mean(MTBW)") << set name("MTBW (w/Outliers)");
column(dt, "N(MTBW)") << set name("nMTBW");
pmroz
jmpbeginner
thank you!!
