chemguy
Help with changing default Scientific notation to user defined scientific notation
I need some help in  converting the following column of data (e.g. 2804504000) to User Defined Scientific format (e.g. 280.45E+6) instead of JMP default (2.805e+9). Is there any script I can use to change the Column Properties?
Thanks.
Original Data
2804504000
3195354000
3709419000
1422125000
3510051000
2892291000
JMP Default when you change the Format to Scientific
2.805e+9
3.195e+9
3.709e+9
1.422e+9
3.51e+9
Desired Output of data in fix Scientific format
280.5e+6
319.5e+6
370.9e+6
142.2e+6
351.0e+6
Jeff_Perkinson
Re: Help with changing default Scientific notation to user defined scientific notation
Hi ChemGuy,
Unfortunately, JMP doesn't offer a way to change the number of digits to the right of the decimal in for Scientific format.
We'll consider this for a future enhancement though.
-Jeff
-Jeff
Jeff_Perkinson
Hi ChemGuy,
-Jeff
-Jeff
chemguy
Thanks Jeff
