tiwitopi
how to close recovery files window?
I am trying to run everything in the background and trying to have no windows open.
By any chance is there a way to close the JMP recovery files window which pops up when I start running the files suggesting me to save anything that has not been saved properly with the previous run?
Thanks!
Re: how to close recovery files window?
Try using the BatchInteractive setting
BatchInteractive(1);
 It is pretty much an undocumented function, that tells JMP to act like JMP is running in batch(no interactive windows) or interactive.
I can never remember if 1 sets it to batch, or if you need to specify 0.  Try it and see if it helps.
