I have two columns in the file, one column is the parameter name, the second column is the parameter value, I want to confirm whether JMP can make a definition: different parameter names corresponding to the parameter value has a different numerical format. For example: the parameter name is TTV is an integer format, and the parameter name is CARRIER CONCENTRATION and RES is a scientific notation.
