how can I get prediction profiler output estimation in a script?
Hi all,
I have an experiment with many outputs, and I want to get the values given by the prediction formula in a script to send them to a data table. Anybody know how to do that?
Thanks,
Jose Angel
3 ACCEPTED SOLUTIONS
Re: how can I get prediction profiler output estimation in a script?
If you select the red triangle next to the Response>Save Columns>Prediction Formula, it will add a column to your data table that has the prediction formula.  If you right click on that column, and go to the Formula (it will have a check next to it) you can view the formula.
The suggestion to save the model as a column formula is a good one. There are many ways to use it.
This example illustrates how you can directly get the value displayed in the profiler as another way:
Names Default to Here( 1 );
fit = dt << Fit Model(
	Y( :weight ),
	Effects( :age, :sex, :height ),
	Emphasis( "Minimal Report" ),
	Run(
		Profiler(
			1,
			Confidence Intervals( 1 ),
			Term Value(
				age( 12, Lock( 0 ), Show( 1 ) ),
				sex( "F", Lock( 0 ), Show( 1 ) ),
				height( 62.55, Lock( 0 ), Show( 1 ) )
		:weight << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
		Parameter Estimates( 1 ), Scaled Estimates( 0 ),
		Plot Actual by Predicted( 1 ), Plot Regression( 0 ),
		Plot Residual by Predicted( 1 ), Plot Studentized Residuals( 0 ),
		Plot Effect Leverage( 1 ), Plot Residual by Normal Quantiles( 0 ),
		Box Cox Y Transformation( 0 )}
fit rep = fit << Report;
prediction = Num( fit rep["Prediction Profiler"][AxisBox(1)][TextBox(2)] << Get Text );
MathStatChem
Try this in your script
rfit = fit << Report;
pf=rfit["Prediction Profiler"] << get scriptable object;
pf << Remember Settings;
dtout = (rfit["Prediction Profiler"]["Remembered Settings"][Table Box(1)]<< Make Into Data Table);
MathStatChem
	Y( :weight ),
	Run(
		Profiler(
			1,
			Term Value(
