BookmarkSubscribeRSS Feed
teebahnson
horizontal scrolling in a data table
I recently purchased a fancy new mouse (Logitech MXMaster) with a second horizontal scroll wheel so that I could more easily navigate across the columns in my JMP tables. The horizontal scroll wheel works in all my other software applications except JMP Pro 12 (I'm using Windows 10).  Any ideas on how I can change the settings in JMP Pro 12 to allow the horizontal scroll wheel to work?   thanks, Tee
Re: horizontal scrolling in a data table
There should be the option to set up application specific responses in the Logitech software.  If JMP isn't picking up the behavior from windows 10 natively you could try and explicitly setting up that functionality in the logitech utility.
best,
M
