cgomez
function for room number by floor
In a data table, I have a  column of room numbers, such as 103, 104, 208, 307, 409, 502, 604, 608.  I would like to create a new column of floor for each value such as 1, 2, 2, 4, 5, 6, 6.  I am not sure how to use the function option for this task. Can someone help with this?
pmroz
Re: function for room number by floor
Looks like your column is a character, so change the formula to:
floor(num(:room) / 100)
reeza
Is the first digit the floor, this will work for rooms such as 1202 as well that are on the 12th floor.
you can do the following
floor(room/100);
cgomez
Thank you.   get the following result.  Can you tell me if you have seen this and what it may mean?
pmroz
cgomez
Sorry I meant that the result would be 1, 1, 2, 3, 4, 5, 6, 6.  Essentially the 1st digits.
