Sebnem
create new tables from a stack table
I would like to create new tables based on selected rows in "label" column. For example I would like to select rows starting with "Rpp" such as
Rpp_Center
Rpp_North
Rpp_East
Rpp_MidEast
Rpp_MidWest
Rpp_South
Rpp_West
Rpp_North
and create a new table called Rpp. Then, select rows starting with Wig_350
Wig_350_Center
Wig_350_East
Wig_350_MidEast
Wig_350_MidWest
Wig_350_South
Wig_350_West
Wig_350_North
and create a new table called WIG.
Then, repeat this for all the labels .
Can you show how to scrip this?
Re: create new tables from a stack table
You could get quite far by creating column which has the "short" labels which you want to create new datatables by and then using subset platform with subset by:
You just need to figure out how to separate "short" labels from your Label column. One way could be possibly with formula like
Left(:Label, Contains(:Label, "_", -1) - 1)
or
Word(1, :Label, "_")
To do this interactively, go to the area at the top of the Row State column(the column that has the row numbers).  Right click and select
       Row Selection+>Select Where
Then in the dialog that is opened, specify to find rows where Label Contains "Rpp"
It will then select the rows you want
Now go to
     Tables=>Subset
The Subset dialog window will open. Specify to only subset Selected Rows, and all columns
It will then create the new table you want
Repeat the same process for your Wig_350 subset you want.
If you want to do this using JSL, the below will do the same
dt << select where( Contains( :label, "Rpp" ) == 1 );
dt << subset( selected rows( 1 ), selected columns( 0 ) );
dt << select where( Contains( :label, "Wig_350" ) == 1 );
