joann
concatenating data of the same category with delimiter in the same cell
Hi, I have an input as below. How do I generate the summary output as below, using jmp existing function like tabulate or other, concatenating the market with delimiter "|"?
Once we have the output, how to use jmp function to convert the output back to the input format?
Thank you!
input
CodeMarket
1A
2A
3A
1B
5B
1C
7C
7A
output
CodeMarket
1A|B|C
2A
3A
5B
7A|C
Re: concatenating data of the same category with delimiter in the same cell
With some tinkering around in Tables and Cos menu I might have figured it out. Image instructions follow:
Start:
1. Tables / Split
2. With A, B and C columns selected go to Cols / Utilities / Combine Columns(might want to keep Multiple Response, depending how you use the data)
3.  Delete unnecessary colums A, B, C
4. To go back, select Market column and go to Cols / Utilities / Text To Columns
5. Tables / Stack
6. Delete Label column
Start:
1. Tables / Split
5. Tables / Stack
joann
This works perfectly! Thank you so much!
