close all like this user-defined outlines
Hello, I'm trying to replicate the behavior of <<close all like this for outlines I've created from scratch in JSL.
From the scripting index:
Syntax: obj << Close All Like This
Description: Closes this Outline Box and all Outline Boxes in the display tree with the same original title or help key.
If I inspect a JMP Platform (Fit Least Square) with Show Tree Structure, I do see HelpKey=FitLS etc.. and in fact these outlines respond to ctrl-close/open or to close all like this.
6 REPLIES 6
Re: <
To my knowledge you cannot add custom properties such as helpKey to display boxes (I have asked this from developers).
MathStatChem
Re: <
Is there a wish list item for this?
Re: <
I don't remember that I would have created one. I have told about the wish to developers in JMP Discovery Summits and maybe shared it in some EA feedback.
MathStatChem
Re: <
Re: <
This is one of the places where I would maybe even consider creating JMP Class. You could also collect the references and just close them normally.
Re: close all like this user-defined outlines
For the case where the title of the outline boxes are the same, this approach might work:
(Report( obj ) << XPath( "//OutlineBox[text()='Name']")) << Close( 1 );
 This approach could be extended to cases where the match is not exact.
