  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Add Properties to Display Boxes
For general JSL programming, it would helpful if display boxes such as Outline Boxes, Table Boxes, Graph Boxes could have user/programmer defined properties assigned to the display box.
Add the ability to assign properties to display boxes.  I propose something like the "Add Context("label", "value")" message that can be sent to Outline Boxes.  Perhaps an <<Add Property(key, value) or <<Add MetaData(key, value).  Make these properties retrievable using a JSL message like <<Get Property(key) or <<Get MetaData(key).
Why is this idea important?
This would create additional options for JSL programmers to develop reports that are more easily dynamic and controllable.  See, for example, https://community.jmp.com/t5/Discussions/close-all-like-this-user-defined-outlines/td-p/935787.
1 Comment
scott_allen
