carloaz
how to work out std error in Overall Bias Linearity and Bias
can i know how the std error of 0.002981 in the overall bias is worked out ?
DF are 10 , Anova I performed too , understood the individual std error but not the overall ?
carlo
Re: how to work out std error in Overall Bias Linearity and Bias
Open your report, select "?" from toolbar, click on the part you are interested in. Generally you get quite close to your answer.
carloaz
thankyou I solved it :
MS from Anova is 0.0001333
That is variance
Root variance = std dev
( std dev / ( root 15 ) = std error
thank you
