Françoise
analyse/tabulate
is it possible to use thousands separator when we build an Analyse/Tabulate?
when we have several numbers, it will be more easier to read the table.
Best regards
dale_lehman
Re: analyse/tabulate
Well, I just did it on mine and it works.  I've attached an example - again, I might be misunderstanding what you want to do.
7 REPLIES 7
I do not see a method for setting the thousands separator in Tabulate.  Maybe another Community Member will have a method.
I do suggest that you add this need to the JMP Wish List
See correct answer below
Françoise
Ok, thanks.
done!
dale_lehman
Perhaps I don't understand your question.  While you can't set the thousands separator within Tabulate, if you set it in the formatting for the column, Tabulate will preserve that formatting.
Françoise
when you create a custom table of summary statistics, even if your column is tabulated with thousand separators, you will not have in this table the thousand separators.
best regards
dale_lehman
Françoise
you are all right !
thanks
I discovered my issue that lead me to my false statement.  I turned on the thousands separator and ran the Tabulate, and no separations appeared.  However, my error was that since I was summing the data, I had not increased the definition of what format to use.  Once I increased my Fixed Dec format to allow for sufficient characters, the thousands separator appeared...….sorry for my misleading.
