guy
guy
add a new radio selection box based on user input
Hi all,
I want to creat a window with two  depanded radio box.
the 1st redio box will ask the user to choose a number between 1 to 3
then,  based on the user selection, a new redio box will pop up below the 1st radio box with the flowing rouls:
if user select "1" --> the 2nd radio box will contain 2 options "a" and "b".
if user select "2" --> the 2nd radio box will contain 3 options "a" , "b" and "c".
if user select "3" --> the 2nd radio box will contain 4 options "a" , "b" ,"c" and "d".
the idea is to learn how to add a new radio selection box based on user input
thanks!:)
Re: add a new radio selection box based on user input
Here are a couple of ways to do this.....others exist too
rad1 = Radio Box( {"a"} );
rad2 = Radio Box( {"a", "b"} );
rad3 = Radio Box( {"a", "b", "c"} );
New Window( "Test",
	vlb = V List Box(
		radtest = Radio Box(
			{"One", "Two", "Three"},
			If(
				radtest << get == 1,
					Try( vlb[Radio Box( 2 )] << delete );
					vlb << append( rad1 << clone box );,
				radtest << get == 2,
					vlb << append( rad2 << clone box );,
				radtest << get == 3,
					vlb << append( rad3 << clone box );
New Window( "Test2",
	vlb = V List Box(
		radtest2 = Radio Box(
			If(
				radtest2 << get == 1,
					rad12 << visibility( Visible );
					rad22 << visibility( Collapse );
					rad32 << visibility( Collapse );,
				radtest2 << get == 2,
					rad22 << visibility( Visible );
					rad12 << visibility( Collapse );
				radtest2 << get == 3,
					rad32 << visibility( Visible );
		rad12 = Radio Box( {"a"} ),
		rad22 = Radio Box( {"a", "b"} ),
		rad32 = Radio Box( {"a", "b", "c"} )
rad12 << visibility( collapse );
rad22 << visibility( collapse );
rad32 << visibility( collapse );
New Window( "Test",
	vlb = V List Box(
			If(
	vlb = V List Box(
			If(
guy
guy
Thank you Jim!
Worked Perfectly :)
