Created:
Oct 26, 2022 04:26 PM
| Last Modified: Jun 11, 2023 4:28 AM(4503 views)
Day1
0
Day2
0.008
Day3
0.008
Day4
0.010
Day7
0.010
Day8
0.011
Day9
0.012
I want to plot a simple figure: Day vs Weight with Graph Builder. But the y axis looks incorrect. It uses my data value in axis, and I can't change it to, e.g. 0, 0.004, 0.008, 0.012...
My weight column is continuous. I just found out that I have value ordering in my column property. Once I removed it, the y axis became normal. Thank you for your help!
Your Time column appears to be a Character column, not a Numeric column. Go into the Col Info dialog and change the Data Type to Numeric, and the Modeling Type to Continuous
Check the Modeling Type on your weight column. I think you'll see that it's either Ordinal or Nominal. Change it to Continuous and the axis will be numeric and continuous also.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '560775' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '560775') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '560775') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
