Level XIII
Workflow Builder + Add-Ins
How can I enable the Workflow Builder  to record actions from Add-Ins like:
- Custom Date Format Writer Data Table Tools Add-in
- rename columns  Scripting Tools
https://community.jmp.com/t5/JMPer-Cable/How-the-new-Workflow-Builder-in-JMP-17-will-save-you-time/b...
12 REPLIES 12
Level XIII
Re: Workflow Builder + Add-Ins
Hi @jules , thank you for the feedback.
Maybe - instead of finding a way how to record the execution of existing addins - add some helper functions which allow JSL coders to develop recordable AddIns?
I have several colleagues who are willing to start recording their workflows via Workflow Builder - but they are no professional coders, so for them it's not possible to add the missing steps. At the moment, any step which involves an AddIn is a killer for them.
As a short term workaround:
@jules , Do you see any possibility to detected (not: record) the execution of commands via the main menu?
Workflow Builder will get much more useful when it gets the possibility to add "dummy" workflow steps like:
  1.  a window informs the user that some manual steps are necessary.
       "Please click OK when you finished the manual steps".
  2.  main workflow ist paused
    - in parallel, the AddIn/manual step is triggered, e.g. via main menu("menu item")
    [the user can apply the manual steps - and take as much time as needed]
  3. after clicking on OK, the workflow will continue with the next step.
Level XIII
Wow, the workframe for
  2. ...
is already there:
A MODELESS window, which pauses the execution of a Scripted Workflow .
Amazingly useful - many many thanks to the invetors : )
Level XIII
Very helpful functionality in combination with the trick :)
Multiple File Import(
	<<Set Use File List( 1 )
) << create window();
source:
Using-Point-and-Click-and-Basic-Code-Cracking-Skills-to-Import/
by @wendytseng  and @monique_lander
