mward
Word density
Hey there,
Does anyone have a way to create a word density distribution for a column of textual data in JMP?  Basically I'd like to create a summary table that has every word in the data file and a column showing how many times it appears.
Thanks!
Matt
Re: Word density
use
proc means data =dsname n;
class varnm;
run;
give the varnm of the word variable name
otherwise use first.varnm and last.varnm
pmroz
Re: Word density
Here's a JMP solution.  This is the JMP discussion forum after all.
dt = New Table( "Word Table",
    Add Rows( 9 ),
    New Column( "Column 1",
        Character,
        Nominal,
        Set Values(
            {"The quick red fox jumped over the brown log",
            "Apples peaches pumpkin pie.  If you're not ready holler I.",
            "Apples peaches pumpkin pie.  If you're not ready holler I."}
dtcol = column(dt, "Column 1");
first_pass = dtcol << get values;
// Convert the column to one big string
first_string = concat items(first_pass, " ");
// Remove periods, change two spaces to one
first_string = substitute(substitute(first_string, ".", " "), "  ", " ");
// Parse all values out of this big string, delimited by a space
all_list = words(first_string, " ");
// Add these values to a new table
wordsdt = New Table("Parsed Words",
        New Column("listvals", Character, Nominal, Set Values(all_list)));
// Run tabulate to get a frequency count
words_tab = wordsdt << Tabulate(
    Show Control Panel( 0 ),
    Add Table( Row Table( Grouping Columns( :listvals ) ) )
Re: Word density
This script on the File Exchange might help you: Word Counts to Columns.
-Michael
Michael Crotty
Sr Statistical Writer
JMP Development
