Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
Why graph builder Line chart no connection for missing value not work?
Created:
Aug 11, 2022 06:18 PM
| Last Modified: Jun 11, 2023 4:27 AM(3471 views)
I have a points and line chart below. the pink line in the middle graph is not supposed to connect as the selection is no connection for missing value, other color lines in the middle chart did not connect and bottom chart the pink line is not connected. I have hard time to figure out why.
@r30363 Are you sure that for the pink line there is a missing value in between? Otherwise can you post example data? And we would need version and OS for this kind of issues. For me this feature works as expected.
The sample data table you provided did not have any missing values. Theefore, I modified the table to have a couple of missing values for each level of Cycle2
And the resulting graph honors the No Connection option
