Sburel
Saving a new project using a variable name created within the project
I've put together a script that starts by creating a project. After doing all sorts of things within the project, I get a variable name that want to  use to name/save the project.
I've tried using a global namespace to transfer the variable from inside the project to no avail.
Any suggestion would be very appreciated
Clear Log();
project = New Project();
project << run script(
	dt = New Table( "test table for project", add rows( 1 ) );
	dt << save( "$DOCUMENTS/test delete.jmp" );
	if(isnamespace("trans")==0, trans = new namespace("trans"));
	trans:pjname = "blogus project.jmpprj";
name=trans:pjname;
show(name);
project << Save As( "$DOCUMENTS/" || name );
Sburel
Re: Saving a new project using a variable name created within the project
Found the answer to my own question.
Anyway, using 'this project()' does the trick. See script below
Clear Log();
	this project() << Save As( "$DOCUMENTS/" || pjname );
Sburel
Clear Log();
