lwx228
Why can't this formula do the whole column calculation?
The requirement is that if the number of rows is less than 25 and the rightmost number in the first column is 0, extract the 12 Numbers in the first column, otherwise return 0
If I write the formula this way, it will appear that when the rightmost number in the first column is 1, there will be no result, not even the calculation below.
Thanks for your guidance!
lwx228
Re: Why can't this formula do the whole column calculation?
If( Row() < 25 & Substr( :Label, 25, 1 ) == "0",
Substr( :Label, 14, 12 ),
0
There may be some other issues, but the first thing is that your formula is mixing data types.
The Label column is character. Your formula in the "if" clause is using a substring, which is a character function. That is good.
Your "else" clause just has a zero (0), which is numeric. Put that in double quotes (like you did in the "if"  statement) to get rid of the JMP alert that you captured.
Alternatively, you could put a Num() around the SubStr(Label,14,12) and make sure Column3 is numeric.
Dan Obermiller
lwx228
0
Dan Obermiller
lwx228
Thank you!
OK
"0"
