chriscic42
Why am I getting no K-fold validation for my linear regression? It only shows "."
Doing a linear regression, and both in stepwise and in the final model output it only shows "." under K-fold cross-validation?
Why? I recall seeing a K-fold # for my previous model, though I don't remember the exact section or screen.
SDF1
Re: Why am I getting no K-fold validation for my linear regression? It only shows "."
Hi @chriscic42 ,
  Without some more specifics about what you're doing (e.g. steps and or data table -- can be anonymized), it's hard to figure out the issue you're coming across.
  However, when I try on one of my data table to run the Stepwise Fit personality under the Fit Model platform and select K-fold Crossvalidation from the red hot button, it runs just fine using the Max K-fold RSquare for the Stopping Rule. Also, are you using a crossvalidation column?
  If you can provide screenshots of the steps you're doing or the data table with the script that reproduces the issue, it would help a lot to figure out what's going on in your situation.
Thanks!,
DS
