UserID16644
Whitespaces in plot labels
Hi all,
How can I remove the whitespaces in my plot labels? I'm using this function to plot
varplot3 = Function( { y_param },
	var = Variability Chart(
		Y( column( y_param ) ),
		X( evallist( varlist2 ) ),
		Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
		Mean Diamonds( 0 ), Points Jittered( 0 ), Connect Cell Means( 1 ),
		Show Box Plots( 0 ), Std Dev Chart( 0 ) );
	rvar = var << Report;
	rvar[Axisbox( 1 )] << Show Major Grid( 1 );
	rvar[Framebox( 1 )] << {Marker Size( 4 )};
	rvar[Framebox( 1 )] << Frame Size(700, 300);
	rvar[TextEditBox( 1 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
	rvar[NomAxisBox( 4 )] << {Rotated Tick Labels( 0 )};
	rvar[Framebox( 1 )] << Row Legend( Column( buildname ), Color( 1 ), Marker( 0 ), Color Theme("JMP Default"), Continuous Scale( 0 ) );
	rvar[Framebox( 1 )] << Row Legend( Column( ht ), Color( 0 ), Marker( 1 ), Marker Theme("Paired") );
	g = nitems(varlist2)+2;
	Try(rvar[BorderBox(g+1)] << Delete);
	Try(rvar[BorderBox(g)] << Delete);
	pvar = rvar[Outlinebox( 2 )] << get picture;
I also attached the sample output that does have whitespaces in the label. How to remove the whitespaces? PLs help
ian_jmp
Re: Whitespaces in plot labels
Try this. Make the plot, then right click on the axis to bing up 'Axis Settings...'. Then select 'Short Divider':
If this is what you are after, save the script and steal the extra code you need. You will see something like:
		Dispatch(
			{"Variability Chart for NPN1"},
			"1",
			ScaleBox,
			{Label Row( 1, Tick Mark Style( "Short Divider" ) )}
UserID16644
Hi, I tried inserting the line into my function but it still doesn't work.
rvar[ScaleBox( 1 )] << {Label Row( 1, Tick Mark Style( "Short Divider" ) )};
rvar[Framebox( 1 )] << Frame Size( 700, 300 );
rvar[Text Edit Box( 1 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
    Color( 1 ),
    Marker( 0 ),
    Color Theme( "JMP Default" ),
rvar[Framebox( 1 )] << Row Legend( Column( ht ), Color( 0 ), Marker( 1 ), Marker Theme( "Paired" ) );
Thierry_S
I don't think you need the list brackets { }.
Best,
TS
Thierry R. Sornasse
