HydroBug
When exporting graph as image the background of the graph box remains white even when set as "transparent" in the report preferences.
Hello all -
I am working with JMP Pro 16.1.0. When exporting my graph as an image file, the background of the graph box remains white even when I have set the background as "transparent" in the report preferences.  Below is an example when I exported an SVG file: the titles and axes export as transparent, but the graph box continues as white.
I tried exporting as various types of image files in happens for all of them.  Is there a workaround?
Thank you all!
Re: When exporting graph as image the background of the graph box remains white even when set as "transparent" in the report preferences.
Also, since you are using svg, you can edit the svg after it is written to remove the rect fills. For some reason, there are two. You could use a text editor, or use JSL to do it:
dt = Open( "$sample_data/big class.jmp" );
g = dt << Graph Builder(
	Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 2 ) ) )
Report( g ) << savepicture( "f:/g1.svg", "svg" );
Open( "f:/g1.svg" );
txt = Load Text File( "f:/g1.svg" );
/* remove the rect fill
<g fill="#DDDDDD">
 <rect stroke="none" x="84.5" y="36.5" width="500" height="409" />
</g>
While(
	Pat Match( txt,
		("<g fill=" + Pat Break( ">" ) + ">" + Pat Span( " \!n\!r" ) + "<rect stroke=" + Pat Break( ">" ) + ">" + Pat Span( " \!n\!r" ) + "</g>") >> deleted,
	Show( deleted )
Open( Save Text File( "f:/g2.svg", txt ) );
g2.svg
Vote for my wish: Transparent background color for graphs
<g fill="#DDDDDD">
</g>
While(
	Pat Match( txt,
	Show( deleted )
g2.svg
HydroBug
Oh WOW Craige - This works fabulously!  Thank you, thank you!
It also go rid of the grid in between frame boxes, but I managed to get them to show up gain.  Thank you, thank you, this is hugely helpful.
-Erika.
