lala
Level IX
When JMP mapping, how can I load an image with a transparent background to keep the background transparent?
JMP maps the following JSL and then loads the transparency image with a transparent background.
Save as a new image, how to use JSL?
dt=Open("$SAMPLE_DATA/Big Class.jmp");
p1 = dt << Graph Builder(
	Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ) ),
	Elements( Bar( X, Y, Legend( 5 ), Response Axis( "X" ) ) )
Re: When JMP mapping, how can I load an image with a transparent background to keep the background transparent?
