UserID16644
Level V
How to use wildcards in matching columns (Update Table)
Hi all,
How can I update a table using wildcard? I already tried to create a column with a substring formula
dt << New Column( "Code Ref", Formula (Substr(:Code, 1, 4)) );
TableA
CodeNameAge
ABCD456Ann12
ABCD123Roy16
ABCD678Jean11
TableB
CodeNameAge
ABCD543John12
FGR263Mike13
ABCD975Rose8
After table update:
CodeNameAge
ABCD456Ann12
ABCD123Roy16
ABCD678Jean11
ABCD543John12
ABCD975Rose8
But I cannot use Code Ref as matching columns when I use the UPDATE table because it results into blank columns. How can I use wildcards to update table in matching columns?
Re: How to use wildcards in matching columns (Update Table)
You cannot really use wildcards in JMPs Join/Update platforms (you could use SQL query to join the tables though) but I'm not exactly sure what type of update you are trying to perform? Are you trying to concatenate only rows which have Code starting with ABCD?
UserID16644
Level V
I am trying to update TableA with TableB using the Code column. I could also be needing some columns from TableB that should be in TableA
