pauldeen
Variability chart misbehaving on JMP 17.1?
When I generate a variability chart in JMP17.1 I get the question if I want to add Group means, when I enter ok and save the script it will contain a section to include the group means. Yet when I re-run that script it shows the same prompt again asking if I want to see the group means. Can anybody reproduce this problem? I did not have this problem in JMP16.
Example script:
dt << Variability Chart(
	Y( :height ),
	Model( "Main Effect" ),
	X( :name, :age, :sex ),
	Sigma Multiplier( 5.15 ),
	Variability Analysis(
		:height,
		Connect Cell Means( 1 ),
		Show Group Means( name, age ),
		Show Grand Mean( 1 ),
		Std Dev Chart( 0 ),
		Mean of Std Dev( 0 ),
		Group Means of Std Dev( 0 ),
		AIAG Labels( 0 ),
		Mean Plots( 1 ),
		Std Dev Plots( 0 )
Pops up this window:
Which it shouldn't as it is already coded in the script.
I'm looking for a scriptable way to get the group means to show without it prompting the user.
MRB3855
Re: Variability chart misbehaving on JMP 17.1?
Does it help if you change the preferences in that platform? See yellow highlight below.
pauldeen
No change
AFAIK, that pop-up occurs for every version of JMP I have ever used.  I have it set in preferences as above and it will always show that popup.
pauldeen
I think it happens when you absorb all repeats in your factor structure. So single observartions per category. But still, the answer to the question is coded in the script so why bother the user? I'll submit it to support
It happens when you want any summary means (e.g., cell, group, grand).  The popup allows the user to de-select those that are pre-set by preference.  It provides more options.  It takes a quick OK to get the plots you want.  I think it is a good feature, but to each his own.  In any case, this has been the behavior for at least the last 5 versions of JMP.
Desert_Rose
orig_pref =Get Platform Preferences();Set Platform Preferences(Variability Analysis(Show group means( 0 ))); //suppress setting in JMP 17
//Your Code
Eval(orig_pref); //return original preference
Hope this helps
