shoffmeister
Mar 27, 2015
Using two different configurations of JMP13
Hi there,
as I am giving a lot of trainings and I am working a lot with JMP for myself I would like to set up my system (Windows10) so that I have two different shortcuts on my desktop:
1. Fresh and clean JMP for the trainings: All default settings, no loading of addins, no recent files, ... basically a JMP how it looks when newly installed.
2. My customized version of JMP: a lot of adjusted settings, plattforms, addins, etc.
Is there a way to do this e.g. by using two different preferences-files? Or would I need to use to seperate installations of JMP?
shoffmeister
Mar 27, 2015
Solution
Re: Using two different configurations of JMP13
Ah nevermind. I just found this https://community.jmp.com/t5/JMP-Blog/Here-s-how-to-share-your-JMP-Preferences/ba-p/30239 and it sould do the trick!
1 REPLY
shoffmeister
Mar 27, 2015
Solution
