Shadow
Using "Left" on a string
I think this should be easy but have spent too much time trying to figure it out. I have a more complex worksheet with a longer list (that refers to column names that may change) but what I am trying to do is create a new list to be used else where by removing the word "_Yield" from my original list. Simple example below;
<JSL>
exurl = {"Test_Yield, Help_Yield"};
X = Left(exurl, Contains( exurl, "_Yield" ) - 1 );
For this I want to get X = {"Test", "Help"} but I just get X = exurl
SDF1
Re: Using "Left" on a string
Hi @Shadow ,
  Along with what @JohnDMoore1 suggested for the substitute, which is a great way to do it, another option can be the following:
Names Default to Here(1);
exurl = {"Test_Yield", "Help_Yield"};
x={};
For(i=1, i<=NItems(exurl), i++,
	x[i]=left(exurl[i], Contains(exurl[i], "_Yield")-1);
  I think one of the things that's throwing the Left command off is that it is a multi-element list -- even though the scripting index says it can deal with lists, it doesn't appear to actually have that ability. The For loop helps to build your output variable as a list. Sometimes this kind of approach is more flexible, especially when you have large data tables and need to rename many columns, etc.
  Also, I think there is a mistake in your example url that you gave. You wrote: exurl={"Test_Yield, Help_Yield"}, which is only a single string, not a list. I think what you meant to write is exurl={"Test_Yield", "Help_Yield"} which has the extra quotes and comma separating the elements in the list.
Hope this helps!,
DS
JohnDMoore1
I tend to use substitute in these situations
X = substitute(exurl,"_Yield","");
Shadow
Hi John, Thanks for your reply. I had tried that but still get X = excurl.
SDF1
Hi @Shadow ,
x={};
Hope this helps!,
DS
If you have access to JMP16+, this is a good place to use Transform Each
X = Transform Each({url}, exurl, Substitute(url, "_Yield", ""));
show(X); // X = {"Test", "Help"};
