News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
cchb
Using graph builder to create X grouped data
Hola,
With some previous help I created some graphs such as the one below:
Graph Script:
Graph Builder(
  Size( 676, 477 ),
  Variables(
  X( :Name( "Leaf age (weeks in log scale)" ) ),
  Y( :Name( "Leaf thickness (mm) average RoC" ) ),
  Group X( :Canopy position, Levels( 2 ), Size( 1 ) ),
  Overlay( :Tree )
  Elements( Line( X, Y, Legend( 3 ), Row order( 1 ), Summary Statistic( "N" ) ) ),
  Dispatch(
  "Leaf age (weeks in log scale)",
  ScaleBox,
  {Scale( "Log" ), Format( "Best", 9 ), Min( 1.8 ), Max( 110 ), Inc( 1 ),
  Minor Ticks( 8 ), Add Ref Line( 3, Dashed, "Black", "Y3" ),
  Inside Ticks( 1 )}
  Dispatch(
  "Leaf thickness (mm) average RoC",
  ScaleBox,
  {Add Ref Line( 0, Solid, "Black" )}
  Dispatch(
  "400",
  ScaleBox,
  {Legend Model(
  3,
  Properties(
  0,
  {Line Width( 3 ), Marker( "FilledCircle" ), Fill Color( 0 )}
  Properties(
  1,
  {Line Color( -16711680 ), Line Width( 3 ),
  Properties(
  2,
  {Line Color( 73 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  3,
  {Line Color( 24 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  4,
  {Line Color( -16738560 ), Line Width( 3 ),
  Properties(
  5,
  {Line Color( 68 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  6,
  {Line Color( 14 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  7,
  {Line Color( 0 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  8,
  {Line Color( 75 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  9,
  {Line Color( 1 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  10,
  {Line Color( 20 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Properties(
  11,
  {Line Color( 42 ), Line Width( 3 ), Marker( "FilledCircle" ),
  Fill Color( 0 )}
  Dispatch( {}, "graph title", TextEditBox, {Set Text( "" )} ),
  Dispatch(
  "Y title",
  TextEditBox,
  {Set Text( "Average RoC - Mean leaf thickness (mm)" )}
These graphs are based on leaf data I have for 12 different trees, as you can see from the graph above only 4 of these trees have data for both sun (SU) and shade (SH) canopy positions. Out of those 4 trees, 1 tree actually has 3 canopy positions instead of 2: SU, SH Mid and SH Low. What I would like to do now is:
Keep the SU canopy position (left-side graph) as is but on the SH canopy position (right-side graph) I would like to include the data of the 4 trees with the 3 different canopy positions all together and differentiate between the canopy positions with different line styles.
I would be very grateful for advise on how to modify the script above (or the arrangement/categories of my data?) to get this done. I do not write code myself, but I am familiar with using the 'Graph Builder' scripts to do minor changes.
Many thanks in advance for the help, Cecilia
