BookmarkSubscribeRSS Feed
blue1994
Feb 27, 2017
User interface
HI, is it possible that if i want design a user interface from dataview and then save the data in the form of excel by using JSL?
Thanks.
Craige_Hales
Mar 21, 2013
Solution
Re: User interface
Can you give more detail about what you want to do?
App Builder is built in to JMP and helps create GUIs. You can also use JSL to make similar GUIs without App Builder.
JMP can export data as CSV files which Excel can import.  JMP can also read CSV data.  JMP also has an Excel connection to work directly with spread sheets.  JMP can read and write .xls files as JMP data tables too.
JMP can save HTML data.
Craige
Craige_Hales
Mar 21, 2013
Solution
Re: User interface
Craige
