Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
UserID16644
Update table according to the date less than or equal to the reference file
Hi all,
I have 2 tables where the dtA is my original file and dtB is my reference file. What I would wanted to do is to have dtA be updated according to the date less than or equal to the reference file.
For example,
Table dtA
Date ModelQty
06/24/2023A23
06/30/2023A25
07/01/2023A34
07/05/2023A50
Table dtB
Date ModelRef
06/01/2023A100
07/01/2023A150
After updating dtA, the table should look like this
Date ModelQtyRef
06/24/2023A23100
06/30/2023A25100
07/01/2023A34150
07/05/2023A50
Is this possible? Please help
Re: Update table according to the date less than or equal to the reference file
Here is a script that works.  It will not be very efficient if the tables bet real large.
Given your 2 data tables the script will provide the update
Please note that row 4 has an update value, where your table did not have one.  Unless I am misinterpreting your requirement, the last row has a value in the reference table that meets te selection criteria
New Table( "Original",
	Add Rows( 4 ),
	New Column( "Date",
		Format( "m/d/y", 10 ),
		Input Format( "m/d/y" ),
		Set Values( [3770409600, 3770928000, 3771014400, 3771360000] )
	New Column( "Model", Character( 16 ), Set Values( {"A", "A", "A", "A"} ) ),
	New Column( "Qty", Set Values( [23, 25, 34, 50] ) )
New Table( "Reference",
	Add Rows( 2 ),
	New Column( "Date",
		Numeric,
		"Continuous",
		Set Values( [3768422400, 3771014400] )
	New Column( "Model", Character( 16 ), Set Values( {"A", "A"} ) ),
	New Column( "Ref", Set Values( [100, 150] ) )
// This is the code that does the actual update
dtA = Data Table( "Original" );
dtB = Data Table( "Reference" );
dtA << New Column( "Ref" );
For Each( {row}, Index( 1, N Rows( dtA ) ),
	dtA:Ref[row] = dtB:ref[Max(
		dtB << get rows where( dtB:date <= dtA:date[row] )
	Add Rows( 4 ),
	New Column( "Date",
	Add Rows( 2 ),
	New Column( "Date",
		Numeric,
		"Continuous",
UserID16644
Hi txnelson, it is prompting an error like this.
You are most likely running older JMP version than 16 (For Each was added in JMP16). You can fairly easily modify it and change it into For loop
I suspect that you have a version of JMP that does not support
For Each()
so if you change the For Each section to
For(row=1, row<= N Rows( dtA ), row++,
it should work.
UserID16644
Script is working fine now, but I have one last question, is there a way to limit the update to a certain date since the tables will be updated everyday? For example,
Table dtA
Date ModelQty
06/24/2023A23
06/30/2023A25
07/01/2023A34
07/05/2023A50
07/10/2023A65
07/27/2023A68
Table dtB
Date ModelRef
06/01/2023A100
07/01/2023A150
07/20/2023A300
08/01/2023A250
Date ModelQtyRef
06/24/2023A23100
06/30/2023A25100
07/01/2023A34150
07/05/2023A50300
07/10/2023A65300
07/27/2023A65250
I tried using the script, but it overwrites the past dates Ref value with the newest one which is 250. It looks like this
Date ModelQtyRef
06/24/2023A23250
06/30/2023A25250
07/01/2023A34250
07/05/2023A50250
07/10/2023A65250
07/27/2023A65250
The purpose of the Discussion Community with regard to help with scripts, , is not to be an on demand script generation source.  It is here to help individual get past issues with scripts they are developing, and to increase their ability to enhance their own scripts.
If you have not taken the time to read the Scripting Guide, I strongly suggest that you do that.  It will show you the details of the scripting language and you will see from that, that JSL is a full scripting language that can handle virtually anything you can throw at it.  However, concerning your current question, you can easily place conditional "IF()" statements to define when the update should be executed or not executed.  Below is an illustration of such
For( row = 1, row <= N Rows( dtA ), row++,
	If( dtb:Date == Today(),
		If( dtA:date[row] <= Col Max( dtB:date ),
			dtA:Ref[row] = .
There are few different methods of doing this, but JMP doesn't (at least yet) offer such a join directly.
First you can create Ref to your original table (which will be empty) (this step is most likely unnecessary as JMP will add missing columns when concatenating)
Concatenate the tables
Sort by groups and time. Select all the values in Ref column and right click to select Fill missing
Select all rows which have QTY missing and delete those
There are also some addins (and scripts) that can do this join in community. Also you can use SQL within JMP
