I extract data from a database and part of this is a "start time" for a process. The main problem with this is that it is in UNIX format so therefore returns a 10 digit number, I know that the formula for converting this to actual date and time is as follows
( taken from Excel)
=CELL/(60*60*24)+"1/1/1970"
so changing a column in JMP should be straightforward but I can't seem to do it. The (60*60*24) is easy but what format do I have to set the +"1/1/1970" to to make this work?
I have attached a data table that contains some dates from the past 6ish years as an example. My feeling is that this might have been asked before but I can't see anything that relates to it.
Regards
David
