mlo1
UTM to decimal Degree conversion of Coordinates
are there any JMP/JSL scripts around to transform UTM to decimal degree coordinates?
Could only find the wishlist entry.
Thank you
https://community.jmp.com/t5/JMP-Wish-List/It-would-be-nice-to-add-UTM-coordinates-to-the-data-forma...
@martindemel
stan_koprowski
Re: UTM to decimal Degree conversion of Coordinates
Hi @mlo1 ,
How would you prefer the conversion to work?
A column dialog box to identify the various UTM variable names
UTM column selection dialogUTM column selection dialog
and then an output table with latitude and longitude coordinates
UTM to latitude and longitude coordinatesUTM to latitude and longitude coordinates
Would you need to go in the other direction? What Geodatum's would need to be supported? WGS84?
cheers,
Stan
mlo1
Hello Stan,
Accidentially I pressed the solved button.
I am not an expert on Geo data and still with JMP17.2 in case there are changes in JMP18
I am just using it from time to time for visualisation of election data.
While the federal goverment is providing the election districts in decimal degree it is easy to get the maps in JMP.
The states are using different geo data format as shown e.g. for Hessen and Bavaria in the attached picture.
May be the *.prj Information can be used for convertion into decimal degree which is used by JMP.
I attached the three different map data.
Best regards
Mirko
image001.png @martindemel @Lisa_Daroque
This looks amazing, what it the Add-in or the way to acces this dialogue box?
stan_koprowski
Hi @SpendingHamster
It's been a while since I wrote the first pass of the code.
Let me know if you would be ok with a basic workflow as  shown above with the basic steps:
  • Open input file
  • Verify inputs / error checking
  • Assign input columns to roles
  • Output a JMP table with derived latitude and longitude based user  inputs
If so, I'll put something together and publish it to the marketplace.
cheers,
Stan
Yes, that would be great. however the data I have only has the UTM numbers (Easting and Northing) using , would that still be feasable with the proposed workflow?
stan_koprowski
@SpendingHamster
Yes I think I could make it work with a limited number of options.
cheers,
Stan
