Hi @carlosariasq,
Just to explain the response from @MathStatChem and answer your question:
Centre points are used to determine if there might be any curvature effect on the response(s). To determine which factor(s) is responsible for this curvature effect, it would require the use of middle levels for the different continuous factors. You can still use centre points to estimate one quadratic effect, but if you have several continuous factors, you may not know with confidence which factor(s) may be responsible of the curvature effect in the response(s). The improvement on the lack-of-fit you see by adding one quadratic effect could imply that you may have to search for the quadratic effects of the continuous factors. Note that you can also look at the different residual plots, to see if a non-random/curved pattern may show a missing term in the model.
In order to differentiate and determine from which factor(s) come the curvature effect on the response, you may need to Augment your design and add quadratic effects in the model for the continuous factors.
Hope this complementary answer can help you,
Victor GUILLER
