BookmarkSubscribeRSS Feed
wakester
Community Trekker
Trying to understand the SNR used in JMP 10 power analysis
In JMP 10 power analysis, the SNR is specified by the user.  Is the unknown sigma in that SNR my pilot study's standard dev divided by sqrt of my design size, or is it just the pilot study standard dev?
Dave Wakefield
statcon
Community Trekker
Re: Trying to understand the SNR used in JMP 10 power analysis
Hi Dave,
it's all about the anticipated RMSE of your model. So if you have a pilot study you would fit an adequate regression model and take that RMSE as an estimator. Another solution would be to use the standard deviation of some replicates in your data.
Bradley Jones wrote a pice on the different components of power analysis in JMP10 (compared to JMP 9): Power Analysis in Custom Design for a designed experiment in JMP 10
Hope this helps.
statcon
Community Trekker
Hi Dave,
Hope this helps.
wakester
Community Trekker
Thanks Statcon.  I was thinking I had to figure out what JMP was doing with the non-centrality parameter to back out effect size.
Respectfully,
Dave
