js1985
Tips to improve control chart visualization
I created several control charts out of a JMP data table and saved everything as a report, I would like to do the following:
  • how can I modify the script in order to get plotted only the last 30 datapoints from the data table?
  • how can I modify the script in order to set the correct size of the chart? Right now every time I open it the graph is compressed on the left side
Thanks for your support!
11 REPLIES 11
Re: Tips to improve control chart visualization
There are a couple of ways to do this.
  1. Select all rows where Row() < N Rows(dt)-30 and then Hide and Exclude them
  2. Create a subset of the last by selecteding all rows where Row() >= N Rows(dt)-30 and then use Tables==>Subset to create a new data table, and run the Chart Builder against the new data table
Unless you have manually changed the chart size in the script, JMP will use the chart size defaults from the preferences.  My suggestion is that you interactively run the chart.  Then manually change the chart size to the size you want it to be, and then go to the red triangle and select "Save Script".  It will have the script code embedded the script it produces, to change the chart size when you run it.
js1985
Hello txnelson,
thanks for your suggestions, unfortunalety what I would like to do is to code in the script something to pickup from the data table only last 30 datapoints automatically without creating a subset of the current data table.
Thanks.
The first option that I suggested does not require subsetting!  See the script belowchartbuilder.PNG
names default to here(1);
dt=open("$SAMPLE_DATA/semiconductor capability.jmp");
// Hide and Exclude all rows except the last 30
dt << select where(Row() < N Rows( dt ) - 29 );
dt << Hide and Exclude;
// Unselect the rows
dt << clear select
// Run the control chart
cc = Control Chart Builder(
	Variables( Y( :NPN1 ) ),
	Chart( Position( 1 ), Limits( Sigma( "Moving Range" ) ) ),
	Chart( Position( 2 ), Limits( Sigma( "Moving Range" ) ) )
// Set the axis parameters
report(cc)[AxisBox(1)]<<min(nrows(dt)-30);
js1985
so I tried to follow your hint, here below the script I'm getting after creating an Individual control chart out of a data table:
Control Chart(
	Sample Label( :Data ),
	Group Size( 1 ),
	KSigma( 3 ),
	Chart Col( :Si STD 3 ppb, Individual Measurement( Avg( 3 ), LCL( 2.25 ), UCL( 3.75 ) ) ),
	SendToReport( Dispatch( {"Individual Measurement of Si STD 3 ppb"}, "IR Chart of IM", FrameBox, {Frame Size( 1301, 208 )} ) )
Where should I paste the code?
Sorry but I'm really a beginner with scripting.
Thanks.
Try this
dt = current data table();
dt << clear select
cc = Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
		Dispatch(
			"IR Chart of IM",
			FrameBox,
To give you the best headstart into the world of scripting in JMP, I strongly suggest that you read the Scripting Guide.
     Help==>Books==>Scripting Guide
and if you are not versed in computer programming in general, I suggest you find o onto the web and search for "free online introduction to programming".
js1985
the script is working fine to select last 30 datapoints but I think I'm getting a problem in setting the min and max on the X axis as per below screenshot:
The line
apparently is not finding the AxisBox() that it needs to change.
  1. Did the example that I included in my Dec 13th 3:23(my time) work correctly?
  2. Is the variable "dt" being assigned to point to your target data table?
  3. Is the "cc" pointing to the Control Chart Platform
cc = Control Chart(
It would help to beable to see the actual code that you are using.  Could you please provide that code?
js1985
So the script I'm using is the following:
dt << clear select
cc = Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
		Dispatch(
			"IR Chart of IM",
			FrameBox,
Regarding the first bullet point, we I rant that code I'm getting this
For points 2 and 3, how can I check this?
Oops....a couple of mistakes.
There needs to be a ";" after the dt << Select Clear;
The Chart you are using needs to have AxisBox(2) referenced, not AxisBox(1);
dt << clear select;
cc = Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
		Dispatch(
			"IR Chart of IM",
			FrameBox,
report(cc)[AxisBox(2)]<<min(nrows(dt)-30);
