gianpaolo
JSL create a Query dialog
hello.
my project is to create a Query dialog with JSL.
i would like to make a dialog box  where i can put a certain number of Lots  and put this  values in a variable
so.. i found the option "COL SPAN BOX"... seems useful.....but work only if i put one lot Number.
here the rudimental script i builted:
test = New Window( "lots query",
   <<Modal,
  <<Return Result,
  Table Box(
     Col Span Box( "Insert Lot_ID", neb = Number Col Edit Box( "Lot List", [0] ), ),
      V List Box(
         Button Box( "test" ), /
         Button Box( "OK", Lot_number = neb << Get ),
         Button Box( "Cancel" )
but my scope is to have the possibility to insert an undefinite numbers of lots and get the values for all of them.
how i can modify my code (or indicate me some other way) to get my scope?
 thanks in advance
Gianpaolo
Gianpaolo Polsinelli
vince_faller
Re: JSL create a Query dialog
Yeah that's native. You don't even need to do anything. Just copy from excel and when you paste it should paste properly.
Vince Faller - Predictum
vince_faller
This I think would work for you.
test = New Window( "lots query", <<Modal, <<Return Result,
	Table Box(
		neb = Number Col Edit Box( "Lot List", J(1, 20,.) ),
    Buttonbox("Add Row",
    	neb << Add Row({.});
    H List Box( Button Box( "OK" ), Button Box( "Cancel" ) )
//because you're using return result you can do this
values = test["neb"];
//get the values that aren't missing
non_missing = loc(ismissing(values), 0);
// set values to only the non_missing values
values = values[non_missing];
But if you can query the database in advance you can select only the lots that actually exist with something like this
//real query would be an open database call
//dt = open database("FAKE DATABASE",
//	"SELECT DISTINCT LOT",
//	"Lot Numbers"
//this is just a fake table for example
dt = New Table("Lot Numbers",
	New Column("Lot", "character", Set Values({"A12", "B36", "C465", "D234"}))
	lots = column(dt, "Lot") << Get Values;
	lb_lots = listbox(lots, nlines(10), values = lb_lots << Get Selected),
show(values);
gianpaolo
woww!!! very nice script Vince
the first solution is the one  closest to my query dialog Query!!!!
if now i have a batch of lots.. and i want to make copy /past in the dialog box.. and get the values do you think is possible?
vince_faller
